I have a code 153 on my explorer. i want to replace the 02 sensor but want to make sure i replace the correct one. As I lay under the car I see one at the bottom of the exhaust manifold before the cat. Is this the right one? ( bank 2 I think)
I have already replaced the one that is behind the cat that on top the exhaust tubing. ( it was real tough to get me hand up there to unsnal the connection!)
...Welcome Rich, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
I have a '96 4.0 as well. When my code came up I went ahead and replaced all 3 while I was under there. I will tell you that I had better luck getting to the one on the passenger side by taking the wheel well out. And to make it worse the Ford guys forgot to put anti-sieze on the threads and it was a BEAR to get out. HINT; Don't forget the anti-sieze compound if you ever need to get them out again.
