Knocking Noise
Old Jun 13, 2005 | 07:57 PM
explorer1120's Avatar
explorer1120
Knocking Noise
I have a 2002 explorer, and lately I have been hearing this knocking noise. I was told it sounds like a octane knock. And I was told to try putting a higher grade gas in and add a can of octane boost. I have done that a few times and still hearing the noise. Any suggestions?
Old Jun 14, 2005 | 05:15 AM
marragtop's Avatar
marragtop
I suggest you pull the codes to see what they reveal.
Old Jun 14, 2005 | 06:49 AM
explorer1120
Thank you for the suggestion
Old Jun 14, 2005 | 12:34 PM
texan2004's Avatar
texan2004
Look for arcing spark plug wires. Could also be that you have some carbon build-up inside the engine and injectors. This stuff cokes up in there then gets and stays hot goofing up the fuel ignition in the cylinders.
Old Jun 14, 2005 | 01:31 PM
explorer1120
Thank You for info, I will check that out
trvctyrich
Dec 9, 2011 03:03 PM
Bodien460
Jan 29, 2006 02:24 AM
jbabbler
3.0L V6
Jan 7, 2005 10:02 PM
jrahn
Apr 11, 2004 09:14 PM
V10 CREW
Modular V10 (6.8l)
Jan 13, 2003 11:59 AM
