Need Help Please!!
Old Jun 11, 2005 | 10:29 PM
tibaiS's Avatar
tibaiS
Exclamation Need Help Please!!
I have a 99 Ford Ranger, When I turn the key on nothing HAPPENS, but when I go to start it up my starter/ignition fuse blows, and I am stumped on to why this is happening...can anyone help me?
-tibaiS
Old Jun 12, 2005 | 07:26 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jun 12, 2005 | 08:37 AM
Rockledge's Avatar
Rockledge
Welcome to FTE!
Sounds like you might have a short somewhere in the starter circuit. First thing to do is follow the red battery cable that goes directly to the starter to see if you notice any kind of problem areas, such as burned or worn inuslation, corrosion at the connections, etc. You should also check in the same fashion the other wire from the starter to the starter relay in the engine compartment fuse box, as well as the black ground wire. Then check the relay itself.
Old Jun 12, 2005 | 01:21 PM
blackandsilver94's Avatar
blackandsilver94
check your selinoide
check the starter seilanoide. i just had a pro with mine.turned the key and nohing happened except a click.so i figured the sarter was shot so i replaceed that with a new one and still had a prob.so i changed the selinoide and it started up just fine
Old Jun 12, 2005 | 02:45 PM
Piffery1's Avatar
Piffery1
Is the fuse that is blowing located in the interior panel on the side of dash or in the power distribution box under the hood? Fuse number and size?
Old Jun 12, 2005 | 08:07 PM
tibaiS's Avatar
tibaiS
We have checked the silanoide and that is not the problem. The fuse is located in the distribution box under the hood. The fuse is a 50 amp, and it is a big one! So if you know anything, please reply!
Old Jun 13, 2005 | 02:01 AM
Piffery1's Avatar
Piffery1
I checked my 1999 Ranger Shop Manual (Vols. 1 & 2) and found nothing on the Power Distribution Box. Also checked my Chilton Manual; all it has on the Power Distribution Box are drawings showing the locations of the fuses and other components. Couldn't find it on any of the wiring diagrams so I can't help you. Maybe someone else on this or other forums knows where to find a complete wiring diagram or schematic that shows the box. Sorry!
Old Jun 13, 2005 | 06:38 PM
tibaiS's Avatar
tibaiS
Smile Thank You!
Well we got my truck going. We found a wire that was grounded that we didn't see before. I thank you all for your help.
