2000 LLS Problem?
Old Jun 12, 2005 | 05:11 PM
Quick_Rod's Avatar
Quick_Rod
Battery is un-hooked. How long must I wait before re-connecting?
Also, will I have to re-program my remote door locks?
Old Jun 12, 2005 | 05:17 PM
01silvergt's Avatar
01silvergt
10-15 min. Not sure, are they factory? If so you should not have to.
Old Jun 12, 2005 | 05:27 PM
Quick_Rod's Avatar
Quick_Rod
Factory? Not sure about the wife's remote but mine's not, although it was purchased from a Ford dealer.
Old Jun 12, 2005 | 05:48 PM
Quick_Rod's Avatar
Quick_Rod
Well other then having to re-set the radio because of unhooking the battery for no reason, everything appears to be working fine.
The reason I said for no reason is because when between the time I posted the air pump question and waiting for a response the LLS kicked in and corrected itself. Stupid as I am I did not notice this when I walked out to re-set the system by unhooking the battery.
Anyway until I can get the new part from the dealer just down the street the temporay fix seems to be working.
Again 01, thank you for all your help and I have given a plug to your reputation in helping me with this problem here at FTE.
Old Jun 13, 2005 | 07:28 AM
01silvergt's Avatar
01silvergt
Not a problem. I was glad I could point you in the right direction.
Old Jun 22, 2005 | 08:42 PM
Quick_Rod's Avatar
Quick_Rod
Hey 01, you wouldn't happen to know the part number for this thing would you? The Ford boys in town seem to think that this is a vacuum line and want their service department to look it over. Must be low on income this month.
Old Jun 22, 2005 | 09:14 PM
orleec's Avatar
orleec
for the connector? try #2L1Z-5B322-AA (got this from a thread here and saved the number)
Old Jun 23, 2005 | 07:31 AM
01silvergt's Avatar
01silvergt
Nope, do not have the number. Try what Orleec, said. You know what the old one looks like, the new one will look similar, but be more robust. Also any good parts guy should be able to look the LLS system up and see the parts.
Old Jun 23, 2005 | 07:52 AM
01silvergt's Avatar
01silvergt
Orleec, has the right part number. It is called a Union repair kit, and its for the main rear air line.
Lama
65
Apr 25, 2010 08:09 PM
jcbfd
Feb 24, 2006 07:42 AM
browneyz1968
Jan 3, 2006 01:34 PM
MENESLIS
Sep 28, 2004 08:42 PM
jundeleon
Mar 19, 2004 05:12 PM
