I have tried several different things to get my 02 to have fogs that work by them self or with highs with no luck. For some reason there are 02's out there with differant wiring harness than others. The fog lamps on mine with the autolamp does not have the power affected by the switch but the ground that is in the steering colum. I have tried several differant mods with no succss. I know that you can get the brite box that will let you have the fogs w parking/low/high but not by them selves.
Here is a link to the fog light fix that has great instructions and pictures. It will tell you the color of the wires and if you have those colored wires this mod should work for you. http://www.ssdiv.com/fogfix.html
I have an 8/02 SD and my switch has the option to pull out the **** in any position but the fog lights only come on with the low beams. I DON"T want them on with the high beams but want them on with the parking lights. What do I need to do to achieve this?
that's what i was afraid of... mine does not... i think i will just hook up a toggle switch as an optional power supply to the fogs ... that way if i'm towing at night and i want to use them with the high beams then i can just leave them of on the dash but turn them on with the toggle... which wire coming from the switch sends the power to the fog lights..? this will be the one i hook the toggle to...
make sure to use a relay though if you run a separate switch.
