Does anyone out there know how to re-wire the fog lights in a 2000 model so they work without the headlights? Is this possible? Or do you know where I can find the information? Thank you.
I just bought fog lights from autolights.com I put them on my truck. It was pre-wired, but when i turn and pull the headlight switch they still don't turn on. I checked the manual and it stated that fuse #9 was the fog lights fuse. I tried to put a fuse in that spot and it wouldn't take. It seems like there is nothing in that slot of the fuse box. Do u know what I else I need to do to get these lights to work?
even though the truck is prewired for the fogs, i believe the switch in the truck is not. You will have to find directions on how to wire it up. I myself just tapped the fogs into the heads. Good Luck.
