It really gets interesting when you then break the carbide drill off in the tap! At work, we burn 'em out with an EDM machine. You DO have one of those, don't you?
Exactly why we never drilled them anyway, we always opted for the edm right off the bat. THe EDM would almost always burn out the HSS. tap faster than burning out a carbide drill.
Back to your original question, breaking the tap into little pieces has always worked for me if I did not have a welder available, welding a nut (I have a TIG machine and prefer it in this instance for the accuracy) onto the tap would be my first choice.
seems like the best "trick" for me is using a punch and then beat the poop out of the tap..you will break it into tiny pieces and then just blow them out of the hole...i'm usually the one they go to at work when taps,carbide pins, are broken at work...forget about the tap extracters,seldom do the work with rusted holes and such..good luck..and remember the safety glasses...
I think about the only way that hasn't been said here is taking a high speed pencil grinder with a round file bit that's smaller then the tap and just grind in far enough to use an easy out. I work on F-16's and that's what we do when working away from out better toys
Happens to me at work all the time. ALL THE TIME!!!!!! Two sure fire ways. Use a small chisel or screw drive and gentle tap (they never break flush) the high side counterclockwise. This takes patience but it will come out. Tap are too hard to drill so forget it.
Last resort: This works but be careful and wear safty glasses please. Place a small ball bearing on the tap and hit it HARD with a hammer. Both are hardened steel but the ball bearing is harder. After several sharp blows the tap will begin to shatter. I have used this once and it does work, though the first option rarely lets me down.
