4.9 Multi-problem Eec-iv ?????
Old Jun 9, 2005 | 07:14 AM
fishdaddy's Avatar
fishdaddy
Question 4.9 Multi-problem Eec-iv ?????
Hello, New To To The Forum. I've Got A 1990 F150 4x4 , 4.9 Liter -(stock). Problems Just Started 137,000 Miles. Rear Fuel Pump Went Out(terrible Noise) Replaced It And The Filter. Next Day Battery Was Dead Charged It Up And Was Dead The Next Day- And Alternator Was Out Replaced It. Now Truck Runs Like Crap. Code Read Erratic Pick-up Assembly And Oxygen Sensor. Replaced Pick-up Assembly, Tfi, O2 Sensor, Plugs, Plug Wires Cap And Bug.retimed Engine. Runs Better. But Cold Start-up Is Terrible, And Sluggish -no Power Like It Is Falling Flat On The Take-off And On Hills. Get A Code 31 With The Engine-on Test. Could My Eec-iv Computer Have Been Burned Out When The Alternator Ran My Battery Dead?????? Also Took To A Ford Dealer For A Code Read. They Said All That They Got Was An O2 Sensor Code. Took To Another Mechanic - He Found A Slight Vac. Leak -replaced Intake Gasket And Vac. Hose. No Change As Far As I Can Tell.help Please- I Am So Frustrated.thanks To All Replies.
Old Jun 9, 2005 | 07:18 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jun 9, 2005 | 09:30 AM
fishdaddy's Avatar
fishdaddy
also just got back from having my EGR valve position sensor test-out ok.
Old Jun 9, 2005 | 12:10 PM
IceWagon's Avatar
IceWagon
Sounds like lack of fuel. Has the fuel pressure been checked with the new fuel pump. Did you replace all of the fuel filters?
Old Jun 9, 2005 | 04:34 PM
fishdaddy's Avatar
fishdaddy
Thumbs up My Current Problem
I Thought It Only Had One Filter On The Frame Rail. The Big One. Checked It Again Today And Seems Clean. Easy To Blow Through. I Think It Is Lack Of Fuel Too. Don't Have A Way To Test Pressure, But Will Probably Buy A Tester Soon. Where Is There Another Filter. The New Pump Had One That I Put On When I Changed It Out. Thanks For The Advice - Much Appreciated.fishdaddy.
Old Jun 9, 2005 | 09:40 PM
IceWagon's Avatar
IceWagon
I am just a novice here. Hopefully some of the pros will chime in and give you some help too. I am not positive how many fuel filters you have, but sounds like the one on the fuel pump and on the frame rail may be all there is.
I think everyone would be interested to know what you have for fuel pressure at the fuel rail.
Did you get the O2 fail code after the 02 sensor was replaced? From what I know you will have serious problems until that 02 sensor is working.
Old Jun 10, 2005 | 09:59 AM
fishdaddy's Avatar
fishdaddy
Yes , Got The Code 31 After Replacement. But I Am Also Told That A Code 31 Lean O2 Sensor Reading Could Be A Lack Of Fuel As Well As The Sensor. , Kinda Makes Sense??????
lildrummer420
33
Nov 28, 2023 03:36 PM
84Fordvan
Computer Chips & Tuners
Mar 14, 2010 11:47 AM
OllieOhNine
1983 - 2012 Ranger & B-Series
Dec 13, 2007 06:32 PM
fishdaddy
20
Aug 5, 2005 08:15 AM
durken
Bronco II
15
Jun 12, 2004 04:22 AM
