Wrap?
Old Jun 7, 2005 | 05:04 PM
wickymustang's Avatar
wickymustang
Wrap?
I recently installed a Walker Downpipe on my 95 F150 with the 300 six cylinder. It may just be me, but I think the underhood temperatures are a lot higher. I was wondering would it be worth my time to wrap the downpipe in header wrap? And where would you guys suggest to look for the best wrap?
Old Jun 7, 2005 | 09:05 PM
Marcus6679's Avatar
Marcus6679
Thermo-Tec makes a good wrap, but most (if not all) header manufacturers will not honor any warranty claims if they have been used. They do help to keep the underhood cooler, but all that heat stays in the headers and can cause them to warp, melt, crack, etc.
Old Jun 8, 2005 | 09:57 PM
kens64's Avatar
kens64
They can also hold in moisture. Uncoated headers or pipes will not last long that way.
Old Jun 9, 2005 | 09:25 PM
wickymustang
OK, so any ideas as to how to cut down on the underhood heat? I would like the rest of the components under there to last and not fail due to the heat.
Old Jun 15, 2005 | 04:25 PM
wickymustang
Is the wrap worth it or is there something else? The underhood temps are noticably higher with the walker pipe so I want to cut that down a little.
Old Jun 15, 2005 | 06:50 PM
kens64's Avatar
kens64
If nothing else, adjust your hood so the rear part (just in front of the windshield) is slightly higher. Not so high that it looks bad, but it will help out a lot with underhood temps.
genotac-f250
6.4L Power Stroke Diesel
13
Feb 14, 2016 06:29 PM
genscripter
Jun 10, 2014 09:51 PM
diehardstroker
30
Sep 11, 2013 07:27 PM
LSO1123
17
Aug 14, 2011 09:11 PM
Epd444
Apr 6, 2007 08:27 AM
