Shaving pistons
Old Jun 7, 2005 | 04:41 PM
alalor's Avatar
alalor
Shaving pistons
I assembled my engine and found that most pistons (new from Navistar) come above the deck about 0.04 to 0.05", while the specs say they should not come over 0.03". The machine shop says I have to have the pistons shaved. The Navistar dealer says the rods got stretched and I need new ones.
Is it safe to shave the pistons?
Can rods stretch?
Thank you,
Al
Old Jun 7, 2005 | 05:19 PM
444dieselrod's Avatar
444dieselrod
I dont see any way that the rods could "stretch". are you sure you torqued the mains down, an untorqued main could give you that extra .01 inch.
I dont see why you couldnt shave them down. I have heard of guys doing it to stock pistons before to lower the compression for massive bost numbers, instead of just buying the low CP pistons.
DIesel Rod
Old Jun 7, 2005 | 05:24 PM
alalor's Avatar
alalor
Hello, well thank you for your fast and informative reply.
Old Jun 7, 2005 | 05:52 PM
barebackjake's Avatar
barebackjake
did you have the crank repolished??? did you plastigauge the main and rod bearings ?
pistons could be shaved but i would find the bottom of the problem. shaving them will lower your compression ratio. leaves more room for more boost though........
Old Jun 7, 2005 | 06:41 PM
touchofgrey's Avatar
touchofgrey
Can rods stretch?
Thank you,
Al
Are these measurements taking into account the thickness of the head gasket?
greentruck72
Jun 17, 2015 09:15 AM
granny_rocket
13
Dec 26, 2014 11:44 AM
Macrobb
Oct 12, 2014 02:08 PM
snakedoc
20
Oct 8, 2012 09:00 AM
