gauge readings
Old Jun 7, 2005 | 05:23 PM
region18's Avatar
region18
gauge readings
What type of boost and egt readings should I have? I have a new Superchips Programmer set on 110 hp with a magnaflow exhaust system.Thanks
Old Jun 7, 2005 | 05:31 PM
444dieselrod's Avatar
444dieselrod
What year truck??? and do you all ready have gauges??? and what are you getting.
stock you should get 1000* and 15-17 psi, SCMT should get 1250* and 22* plus or minus a few pounds of boost. and the pyro too, these are just general area readings.
Diesel Rod
Old Jun 7, 2005 | 05:39 PM
region18's Avatar
region18
On the lowest setting I am getting approx. 20 lbs of boost at 1000 degrees.
On the highest setting I am getting over 25 lbs at 11and change degress because I back off.
Old Jun 7, 2005 | 05:40 PM
region18's Avatar
region18
2002 Crew Cab
Old Jun 7, 2005 | 05:52 PM
444dieselrod
Sounds pretty good. you can stay on it for a few seconds I wouldnt be affraid to hold 1350-1400* for 15 seconds, see what it maxes out at.
Diesel Rod
Old Jun 7, 2005 | 06:48 PM
clux's Avatar
clux
Is your pyro probe mounted pre or post turbo?
Old Jun 7, 2005 | 06:51 PM
johnny8's Avatar
johnny8
my 02 is stock, ecept the wastegate is dissabled... i have gotten 1150 on my pyro... pre turbo... pulling a 10k lb 5ver up some STEEP grades.... and i got 22 psi on my boost guage doing it...! better intake and exhaust will help the egt's.... higher settings on a chip or tuner will hurt..!
Old Jun 7, 2005 | 07:00 PM
region18's Avatar
region18
The egt is installed pre turbo
