piston help?
Old Jun 16, 2015 | 01:38 AM
greentruck72's Avatar
greentruck72
piston help?
so I have a 390 it has shaved heads but I want to put aluminum heads on and the pistons are dished to accommodate the valves( may be just regular dished for all I know) , the heads aren't shaved much so would I need new pistons or would I be fine with what's in it, the heads I want are the Edelbrock complete heads 76cc , I really wouldn't know what I would need to do so any help would be nice
Old Jun 16, 2015 | 01:44 AM
greentruck72
I looked at a picture of my pistons and they are barley dished so I think I would be good, depending on deck height
Old Jun 17, 2015 | 01:12 AM
privateer, eh's Avatar
privateer, eh
Go online and check with a piston manufacturer's piston specs to find out what the compression ratios are with different size chambers. EG flat top piston with 76cc chamber, dished piston with 76cc chamber. Would need to know the height of the piston above the wrist pin to confirm if you have stock pistons.
Old Jun 17, 2015 | 09:15 AM
bkaul's Avatar
bkaul
Valve reliefs and dishing are two different things.
Valve reliefs are to avoid piston/valve interference:
Dishing is typically used to tailor the compression ratio:
It's also possible to do both on the same piston:
^ This is good advice. ^
Blue Rebel
Jan 31, 2015 09:16 AM
zachsherman88
Jun 29, 2009 01:17 PM
Jrock909
Mar 23, 2007 11:40 AM
sabre62
13
Nov 30, 2006 02:45 AM
TMI
Dec 23, 2004 11:50 PM
