Hottfoot
Old Jun 6, 2005 | 07:45 AM
venport64's Avatar
venport64
Hottfoot
What is the hottfoot mod? and will the 10k mod work on a 99
Old Jun 6, 2005 | 08:32 AM
Pocket's Avatar
Pocket
Hotfoot mod is adjusting the pedal to take out the dead spot. That way you touch the pedal and go instead of pushing it down forever to get moving.
10K mod works on all 7.3L PSD's.
I wouldn't do the 10K and the hotfoot mod together. Once you start adding power that pedal gets a bit touchy. At least that's the way mine is now.
Old Jun 6, 2005 | 08:55 AM
venport64's Avatar
venport64
Which one is better?
Old Jun 6, 2005 | 09:31 AM
arninetyes's Avatar
arninetyes
Hotfoot feels like it has more power, but doesn't. The 10K mod actually gives you more power.
Take your pick. I know which one, I'd prefer...
Old Jun 6, 2005 | 01:16 PM
touchofgrey's Avatar
touchofgrey
That wouldn't be sqwalin tires and rollin smoke.....would it Arni? LOL
Old Jun 6, 2005 | 01:46 PM
arninetyes's Avatar
arninetyes
Oh, no, no, no, no!! Of course not!!
Old Jun 6, 2005 | 01:56 PM
touchofgrey
Uh,huh....
Old Jun 6, 2005 | 03:39 PM
Skeeter2221's Avatar
Skeeter2221
I've heard many talk about the 10k mod. As touchofgrey knows I'm just learning. What performance does it inhance and how simple of a job is it.
Old Jun 6, 2005 | 06:53 PM
venport64's Avatar
venport64
Dont know if i will be layin a whole lot of rubber good year wrangler mtr's are to expensive for that
thanks for the info i will try it out as soon as all my deployments are over.
One more Q I have a 99 -250 with the 7.3 of course everything i look at askes if it is 99 or 99.5 other than having the dealer runing the vin is there some other way to tell?
Old Jun 6, 2005 | 08:11 PM
wayfastwhitey's Avatar
wayfastwhitey
O.k. I have the 10k mod and some other stuff but my pedal is kinda "slow" in my opinion....so how do you do this hottfoot modification? I'll try it and see if it helps in the "slow" aspect...lol :-)
Old Jun 6, 2005 | 09:42 PM
arninetyes's Avatar
arninetyes
The 10K mod is easier to do. It will speed up your pedal because it will give better throttle response at low to mid rpms.
Old Jun 6, 2005 | 09:51 PM
lukecline's Avatar
lukecline
I believe that the early 99's have 2" intakes (late 99's and up have 3") and also the psd badge is on the fender and not the door. I know there are more differences than this but i have a case of crs right now.
luke
Old Jun 6, 2005 | 09:54 PM
venport64's Avatar
venport64
Is it late 99 they changed the compressor wheel?
Old Jun 6, 2005 | 10:23 PM
Kwikkordead's Avatar
Kwikkordead
My late '99 had the later wheel. It didn't work very well under heavy load, so I put in a Swisher wheel.
Old Jun 7, 2005 | 07:32 AM
venport64's Avatar
venport64
Thanks for the info
