Hotfoot feels like it has more power, but doesn't. The 10K mod actually gives you more power.
Take your pick. I know which one, I'd prefer...
I couldn't choose, so i did both.... but instead of the 10k... used a 5.6K on a switch.... and i have a "modded" version of the hotfoot mod.... my own personal home brew....
there is a lil tab on the pedal, that when you push on the pedal, the tab will close a switch, and the PCM will get a signal from it to start revving the engine.
the mod involes bending this tab out, so that you just barely have to push the pedal to get the switch to close. bend the tab AWAY from the switch, or towards the drivers seat.
the is more to the mod, which involves indexing the rheostate, so that a WOT the rheostate will send more juice to the PCM, thus tell the injectors to give more fuel.
the last part most don't do, I did it and it really made a touchy throttle so I just bent the tab.
