Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Air Compressor cfm calculator
Old Jun 5, 2005 | 07:50 PM
reamer's Avatar
reamer
15 cfm at 90 psi, is = to ? cfm at 40 psi?
Is there a formula?
Thanks
Reamer
Old Jun 5, 2005 | 08:21 PM
AXracer's Avatar
AXracer
There might be, but it would be dependent on the design (single stage, dual stage, # pistons, oil or oiless, motor voltage and RPM would make a difference in efficiency IMHO), but you might check the manufacturer's web site cfm@ 40psi is usually given in their specs. How much you looking for? A compressor that big will probably run anything but a big sandblaster if it's got a 60gal+ tank. Things to keep in mind:
compressor specs are usually inflated (no pun intended!) They are measured at the compressor outlet without restriction or a load, by the time you add in a regulator, plumbed distribution piping, drier, oil extractor, 50' of airhose, and an air tool you be pushing 1/2 or less than the specs thru the tool. Next the airtool manufacturer's spec is usually the min airflow required to make the tool work (barely!) you aren't likely to be very happy with the performance if your compressor is just pushing the minimum needed.
Old Jun 5, 2005 | 08:40 PM
Torque1st's Avatar
Torque1st
Posting Legend
Moved to proper forum.
Old Jun 6, 2005 | 08:01 PM
Crash687's Avatar
Crash687
to add on, depending on the orfice(load) the cfm would vary at 40 psi.
as far as on output of a compressor you probably would not see much more than 3 to 4 cfm.
Old Jun 6, 2005 | 11:16 PM
fixnair's Avatar
fixnair
Without the manufacturers horsepower curve anything else is just guessing. As pressure goes down volumnmetric efficiency goes up. Just how far is dependant on design criteria. Eg. Bore size vs Stroke and valve flow rates. Also two stage vs, single stage ?????????
Contact the manufacturer.
bigtexan99
Jul 17, 2015 11:01 AM
dmarsh2400
Oct 2, 2012 08:17 AM
ErrorS
Garage & Workshop
Mar 1, 2008 10:47 PM
afinepoint
Garage & Workshop
34
Oct 27, 2007 04:30 AM
reamer
Jan 16, 2005 01:30 PM
