4.6L miss
Old Jun 5, 2005 | 03:27 PM
couleeman's Avatar
couleeman
4.6L miss
I have a miss on my 01 Supercrew with the 4.6L. It doesn't throw any codes, but you can feel the miss during accelleration. The plugs are a couple months old, and I could't see anything loose. Does anyone have any thoughts on this.
Old Jun 5, 2005 | 10:43 PM
LxMan1's Avatar
LxMan1
Did you replace the boots on the coils when you did the plugs? You could have a bad one.
Old Jun 6, 2005 | 07:26 AM
couleeman's Avatar
couleeman
I thought the COP was all one peice with the boot. I do have a couple extra coil packs that I thought about switching a couple at a time to see if that is the problem.
Old Jun 6, 2005 | 07:15 PM
scb713's Avatar
scb713
i have the same problem on my 97. any answers?
i have the same problem. any answers?
Old Jun 6, 2005 | 09:40 PM
couleeman's Avatar
couleeman
Mine finally threw a code today (took about 3 days, but then that was only 20 miles as the truck doesn't really go anywere). Ended up being a bad COP (#6). Replaced the COP and all is good.
Old Jun 12, 2005 | 11:01 AM
osucharger's Avatar
osucharger
lucky you. i've gone through plugs and coil packs and mine's still jacked up
Luke--
Old Jun 12, 2005 | 07:52 PM
brad1974's Avatar
brad1974
Hello,Mine through a code that said a missfire on cylinder #1. Replaced the coil and the plug,ran fine for about 9 days and then started sputtering again and through the same code on the same cylinder. What can I do now? Is there a chance some water got trapped around the plug when I had the engine detailed? If so, shouldn't it have dried up(evaporated)by now? Thanks
BRAD
Old Jun 12, 2005 | 10:25 PM
osucharger's Avatar
osucharger
man i haven't the foggiest. whatever the design is it seems to have one fatal flaw. it doesn't like moisture. it seems fantastically sealed from the factory but with age, parts replacement and/or water under hood look out! i'm gonna take mine over to ford here and see how much they're gonna rip me off to fix it whenever I get the money saved up. can't be too terribly much considering i've replaced all the parts already.
Luke--
Old Jul 17, 2005 | 10:47 AM
mjwalsh74's Avatar
mjwalsh74
I have a 98 F-150 4.6L had missing problem, spent $900 at dealer for new intake gaskets, tune up, It kept happening, turns out it was the coolant line on the passenger side fire wall right above the rear spark plug was leaking into the spark plug boot area and shorting it out temporarily!! Check this for leakage, good luck...
Old Jul 17, 2005 | 03:55 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome scb713 and mjwalsh74, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jul 17, 2005 | 06:48 PM
osucharger's Avatar
osucharger
Mine is fixed. Ended up being a completely roasted spark plug wire. Didn't even think of replacing them since they only had about 5k from dealer replacement. I got suspicious after a while, took the wire apart at the boot and BAM. 'Bout 6 inches of the wire was toasted. No element left inside or anything. Of course Ford won't replace...says it's been too long and my warranty for the wires is voided. Stealership...
Oh well, now I have home made Superconductors up under there. Red wires are pretty!
Luke--
cghstrojan08
1997 - 2003 F150
Dec 17, 2012 10:19 PM
BJWinter
1997 - 2003 F150
13
Feb 19, 2007 06:15 PM
menzo
1997 - 2003 F150
Feb 13, 2006 05:43 PM
Jarrett T
Modular V8 (4.6L, 5.4L)
Sep 28, 2005 02:44 PM
CMWINTER
1997 - 2003 F150
May 29, 2003 07:29 AM
