rough idle
Old Jun 4, 2005 | 03:39 PM
Mikes95's Avatar
Mikes95
rough idle
2005 with the 5.4, 1300 miles
I've noticed a rough idle on cold starts. It smooths out quickly as it warms up and arrives at normal rpm. No hesitation or miss at speed or under load. Gets comparable gas milaege to what the rest of ya indicate. I'm wondering if this is what I can expect with a new engine untill it breaks in. My 95 Bronco (5.0) always ran smooth from start-up. Just curious what ya all think. I'm a long way from my dealer and not in hurry to take it in.
Thanks,
Mike
Old Jun 4, 2005 | 07:10 PM
EnergizerBunny69's Avatar
EnergizerBunny69
As far as me, I have the 4.6 in a '04 Screw. I did not have any problems like that with my truck. I purchased mine in July of '04. At the very first oil change, I switched to FULL synthetic motor oil. I currently have 24,919 miles on my truck & knock on wood, I have not had any problems with my motor, of any kind. I would highly reccommend, TAKE IT TO THE DEALER. DON'T let it keep going and not do anything about it. "Haste makes waste". Get it checked out. Remember.....you don't have to take it to the dealer you bought it from. They would probably prefer that you did though. But by all means, take it to a Ford shop.
Old Jun 4, 2005 | 11:45 PM
ttincali's Avatar
ttincali
I also am having the rough idle at start up. Mine is also a 2005/5.4 just hit 2000 miles. It does go away within a few minutes after it is warm. I was going to wait a few more miles to see if it was a new engine break in issue as well.
Old Jun 5, 2005 | 09:10 AM
medik13's Avatar
medik13
I too have the same problem. At first my RPM's were going up when I started the truck ans within a couple of seconds, it would come down and idle fine. I took it into the dealer and they reflashed the PCM. Now I am having exactly what you have described and oinly have 1400 miles on the odo. Someone please help us find a solution!
Old Jun 5, 2005 | 10:39 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome ttincali, and medik13, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jun 8, 2005 | 07:53 PM
Mikes95's Avatar
Mikes95
ttincali and medik13,
I took my truck to the dealer and they updated the computer. I was told that there is a TSB for the “rough idle on cold starts” condition. So far it is considerably better. The sticker under the hood is hard to read but it looks like TSB 5102. I’ll keep you posted on the improvement. Good luck.
Mike
Insley95
Jun 11, 2013 09:42 AM
IHMANKY
Dec 12, 2010 09:02 PM
Billybob12
1978 - 1996 Big Bronco
Apr 5, 2010 11:18 PM
swann79
Aug 3, 2004 01:48 AM
gts95
Oct 2, 2001 09:14 PM
