Flex-plate runout...how much?
Old Jun 4, 2005 | 12:08 AM
53fatfndr's Avatar
53fatfndr
Question Flex-plate runout...how much?
I just got my C6 back from being rebuilt, it was destroyed There are a handful of reasons that may have caused this, one of them being a bent flex-plate which would have caused the torque converter to sit wrong in the pump. Anyway, I need to check the runout on the flexplate (if it is bent up) and was wondering what the maximum limits should be..... a couple thousandths or what? I'm looking for an exact range, it is for a '71 400
Old Jun 4, 2005 | 06:59 PM
grclark351's Avatar
grclark351
the only spec i see in the factory engine manual is for OD run-out, which i take to mean lateral woble(affecting ring gear/starter) when looking at the back of the engine/flexplate. that spec is .020". the flex is held in place by six bolts on the crank and four on the converter, i think any warpage would be drawn out by the force of all those mount points? but if you can see that the flex is obviously warped/bent when lying on a flat surface....i don't have the chassis manual in front of me but i'll try to find it.
Old Jun 4, 2005 | 08:02 PM
53fatfndr's Avatar
53fatfndr
Any info is appreciated. I'm putting it all back together tomorrow. Thanks!
Old Jun 4, 2005 | 08:20 PM
grclark351's Avatar
grclark351
these flexes aren't too expensive, but sat night/sunday might be hard to get your hands on one.
Old Jun 4, 2005 | 10:03 PM
holland501's Avatar
holland501
I would bolt the torque converter up to the flex-plate and check the run-out on the converter snout. This is the place where any wobble is going the be a problem. If I had any more than 1-2 thou. I would wait until I could talk to a real transmission man. Good luck.
mushman
1983 - 2012 Ranger & B-Series
Jul 3, 2016 07:22 AM
Montync
Apr 22, 2016 01:33 PM
tumble72
Feb 22, 2016 02:20 PM
Toored
Nov 2, 2012 08:01 AM
88F150xlt
22
Jul 19, 2004 03:18 PM
