Hit RESET. Your low fuel chime will come on every ten minutes until you run out of fuel or put more in the tank. But simply hitting reset will make it stop for the time being.
Thank you all for the input. i know the obvious solution is to keep the tank full, but I was wondering if it could be disabled. Like the seat belt warning sound. Any way, thanks again.
The seatbelt warning can be disabled???????????????????????????
On mine, the warning will shut up after a few minutes of intermittent beeps.
The other thing mine does is that I can connect the seat belt and then immediately take it out again and that will stop it...until I shut the truck off and then restart.
Or...................................... Look in your owner's manual, and it will tell you the proper sequence of key, headlight and seatbelt fiddling.
