my 2001 f150 just put a new fuel pump in it last week and now it is chiming 5 times..pauses then 5 chimes pauses (does this 5 times for a total of 25 chimes ..any idea what it is telling me
It's not the fuel pump circuit.
You have something else going on in the warning system like safety belt, key in ignition switch with door open etc.
Good luck.
it has 300k miles on it..for as little as its driven I don't want to put a couple hundred bucks into it for a spare car in the drive way if I don't have to
it had been flashing a flash code for about 5 years..the bulb burned out on the on / off switch for the passenger air bag...the dealer wanted like $90 for the part...I just let it blink (after reading the code and seeing that's all it was) so I have a complete dash and interior available to me and I will replace both pieces .
j just recently got the same chimes 5 x 5. tore my entire dash out trying to figure out what it was, then I came on here and found out what it was and how to fix it. yes it is the bulb in the dash for your airbag. replace the bulb and the chimes go away.
