Aerostar Ford Aerostar
Broken Rear Hatch Latch
Old May 28, 2005 | 09:01 AM
Ricky Sea's Avatar
Ricky Sea
Unhappy Broken Rear Hatch Latch
Any ideas how to open a broken '93 Aerostar XLT rear hatch latch?
Mine just broke, and I am wondering how I can get it open
somehow so I can begin work on it from under the inside panel.
Please advise! And thank you!
Old May 28, 2005 | 12:56 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old May 28, 2005 | 05:00 PM
krankshaft's Avatar
krankshaft
Well while I have never had this problem I would think the first thing you should do is remove the inner trim panel from the hatch.
Then you should see the linkage (a metal piece) that leads from the handle to the latch mechanism make sure the lock is unlocked and pull or push that linkage and it should release and open the hatch.
Old May 28, 2005 | 05:55 PM
aerocolorado's Avatar
aerocolorado
Some other ideas previously posted:
https://www.ford-trucks.com/forums/s...ght=rear+latch
Old May 28, 2005 | 08:03 PM
Ricky Sea's Avatar
Ricky Sea
Thank you! Your reply helped me get into the hatch, now I can see the linkage which seems broken at the handle (plastic?).
Again, thanks!
DaveinTulsa
Nov 17, 2014 01:11 PM
conchstew
Aug 21, 2012 01:25 PM
bryan_1980
Apr 24, 2007 08:17 PM
rikson
Aerostar
Sep 29, 2005 10:24 PM
scholzee
Jul 11, 2005 06:03 AM
