Offroad & 4x4
another ? for ivan
Old May 27, 2005 | 09:24 PM
f150_514ci's Avatar
f150_514ci
another ? for ivan
Ok well im in the middle of the shackle flip and my ? is on the front hangers it says in your gallery that you dropped them 4 1/2 '' now did you have to move them any front or back or straight down ? Oh one more do you have the bushwacker cutouts on your truck ? if so could you get a pic up and how much more of the tire do they cover (my tires are 19x44x16 ) and the truck is a 76' im thinking about doing that to help cover some of the tire.
thanks for all the help
Old May 27, 2005 | 11:33 PM
fishmanndotcom's Avatar
fishmanndotcom
again, i'm not ivan but i'll see if i can't help
all your doing to the front is dropping the hangers. then the rear is where you will be tuning your shackle angles and all and moving your mounts around some
you can move them forward or back if you wanna change your wheelbase any or if you have any clearance issues to take care of but i would suggest just dropping the front mnounts 4.5" and then setup the rear shackles for about 35*
-cutts-
Old May 28, 2005 | 02:45 PM
Stroker_Deezel's Avatar
Stroker_Deezel
ivan is in finland...
Old May 28, 2005 | 08:08 PM
mustange70's Avatar
mustange70
Yeah the only thing in the suspension that you need to move ahead of back are the shackle mounts to correct the angle, the hanger mounts do not need to be moved unles you want to changed your wheelbase.
Old May 28, 2005 | 10:31 PM
f150_514ci's Avatar
f150_514ci
ok thanks Fishy was just in the middle of the flip and wanted to make sure
thanks again for the infinite knowledge
Dholtham
Jan 13, 2013 11:50 PM
45 ACP
Jun 18, 2010 03:00 AM
caprang
Apr 15, 2010 06:13 PM
IntrepidCUB
20
Sep 10, 2007 11:26 PM
farwhitenorth
Apr 24, 2006 01:03 PM
