What air pressure are you running in your BFG A/T tires?
I just got rid of the Continentals and slapped some 305/65/18 BFG All Terrains on my stock wheels on my 2006 F250 4x4. They are E rated tires with a max PSI of 65 pounds. Discount Tire aired them up to full capacity when they installed but I have been lowering the pressure over the past few days because I noticed that the edges of rear tire is not making contact with the pavement due to overinflation.
Right now Im at 50psi in rear and 60psi in front, but still not getting full cantact patch on rear outer edges. Im about to lower even more and go to 45 rear and 55 front while unloaded. Just curious what others are running with thier tire pressure. I paid a lot of money for these tires and want to get the most life possible out of them. Thanks in advance for any suggestions.
Assuming alignment and balance is all good...
Take a temperature scanner, and measure the tires temperature at the inside, outside and center of the tread after a run of about 30 min (for your normal drive).
Tire pressure should be set so the temperature is close to identical at all 3 locations.
This procedure will get you slightly different pressures on each tire, depending on the load of the tire at that particular location.
It will vary according to load and speed.
So the pressure right for 40mph around town is different from the 80mph highway speed pressure.
But the method is tried and true.
BTW, start with the factory recommended pressures in all 4 and then adjust it...
For the OP, google "chalk method".
Yeah, and good luck to you during an insurance investigation when they find you are running 30 psi in a tires that should be at 90 psi.
You should be running what the door sticker says, it is afterall the WARRANTY/ INSURANCE Placard after all.
Josh
Josh
Pigman54
07-29-2014 01:23 PM
45 ACP
1999 to 2016 Super Duty
05-03-2010 10:23 AM
