427??
Old May 26, 2005 | 01:55 AM
mymerc's Avatar
mymerc
427??
I was just asked at our local car club meeting if I was interested in a ford 427 that he called a wide block or tall block motor complete but needs rebuild, for $1000 cnd. What is it in basic terms and what is it worth?
Old May 26, 2005 | 02:06 AM
Bear 45/70's Avatar
Bear 45/70
Check first the bore and strock and then buy it.
Old May 26, 2005 | 04:39 AM
FFR428's Avatar
FFR428
Needsmorecoffee.
He might have been thinking of wedge instead if wide and tall. But anyway $1000 is a steal for a complete 427. There are two types...the center or topoiler and the sideoiler. Also some marine blocks which some were cast as sideoilers but machined as centeroilers. The 427's have a std bore of 4.23 and a stroke of 3.78. Crossbolted maincaps and enlarged oil passages are std. First came out in 63 1/2 and available over the counter well into the 70's. This is THE FE engine to have. The block alone is worth the $1000. G.
Old May 26, 2005 | 04:42 AM
gtex's Avatar
gtex
Uh, yeah. If it is indeed an FE motor (look for 5 valve cover bolts, and check the FAQ for other ID stuff), then confirm that it is a 427 bore of 4.23". I all that checks out, get some casting numbers and post them here so these guys can make sure it's not an over-bored 360/390/428 block.
If that all checks out, and there's not a rod sticking out the side of the block, beg borrow or steal and get it!
Old May 26, 2005 | 05:05 AM
FFR428's Avatar
FFR428
Needsmorecoffee.
You know gtex is right. It could be a 429 or something possibly. The crossbolt mains will be one of the clues to a 427. Three bolts on each side of the block above the pan rail or skirt. G.
Old May 26, 2005 | 09:33 AM
Scouder's Avatar
Scouder
I suspect that he wall talking about a Chevy. The have standard and "Tall Deck" blocks. Ford has no such thing. Go look at it. I'll bet the distributor is in the back.
If it turns out to be a Ford, I wouldn't buy it until I had the bores measured to make sure it isn't already used up. Typically a .030 on a 427 is all you get. If the bores are still within reason, then it is a steal at $1000.
Keep us posted.
-Scouder
Old May 26, 2005 | 01:27 PM
FalconStng's Avatar
FalconStng
hmmmm....did I read $1000 cdn??? Isn't like $500 US...If it's reallly a 427 anyone here will take it!
Good Luck!
Tracy
Old May 27, 2005 | 04:56 AM
FFR428's Avatar
FFR428
Needsmorecoffee.
Uggg, that would be a bummer if it was a chevy 427. Hey you never know....like the lucky guy on the 385 forum that found a BOSS 429 for $200!!!!! I need some luck like that. Let us know what you find. G.
Old May 27, 2005 | 10:55 AM
Mike G's Avatar
Mike G
Good Luck!
Tracy
More like $790.00 USD, but you're right still...
--Mike
Old May 27, 2005 | 02:12 PM
Six Niner's Avatar
Six Niner
hey even if it is a chebby 427 it would still be a pretty good deal, then he could sell it and build/buy a real motor!
arctic y block
26
Jan 30, 2007 08:48 PM
Annihilator
Jan 20, 2005 04:51 AM
blacktail427
Jan 15, 2004 11:19 AM
ranger15
Ford vs The Competition
63
Dec 16, 2003 02:20 AM
anotherF150
43
Nov 30, 2002 07:25 AM
