The clutch on my 93 Ranger 4X4 w/4.0L engine is starting to slip. Vehicle has 156K miles. Supposedly the clutch was replaced at 99K miles by a previous owner ... Question is : If the flywheel needs machining what is the nominal thickness for a new flywheel so I put a shim in for proper dimension?
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Your machine shop should know the minimum thickness. If they cannot get it resurfaced and meet that spec, then the flywheel should be replaced. This is like a front rotor, if it is too thin, then replace it.
I've had mine resurfaced several times without problems. (Young sons learning to drive a manual transmission). So if it has only been replaced once, I doubt you'll have any issues with resurfacing again.
The pressure plate is bolted to the flywheel and won't make any difference how much is shaved off the flywheel.
It it gets too thin it will have a tendency to warp.
We used to shave them paper thin when racing and never worried about shims.
