removing tranny
Old May 17, 2005 | 09:14 PM
deronyv8's Avatar
deronyv8
removing tranny
i am helping a freind pull the tranny out of a ford ranger 1994 4.0 automatic 2x4 what will i need to do this and how heavy is the tranny. any help will be apreciated. thank fellow ford fans.
Deron
Old May 18, 2005 | 09:30 AM
Help I M Stuck's Avatar
Help I M Stuck
you'll need to get a set of good jack stands so you can get the vehicle up high enough to get under it. I use a floor jack to get mine out. DISCONNECT BATTERY, take out the 6 bell housing bots out, remove the inspection cover, remove the starter, need a socket to fit on front balancer bolt to turn motor so you can remove the 4 flywheel bolts, disconnect trans lines, disconnect shifter linkage, remove driveshaft, remove all wiring plugs/spedo cable, support trans with floor jack, remove trans bolts, remover crossmember bolts, carefully let trans down working it back and down. Think that's it. Takes me about a hour to get one out laying on my back..then again i've done it several times.
Old May 18, 2005 | 10:16 AM
AllanD's Avatar
AllanD
Unless the truck in question has a body lift (unlikely on a 2wd)
you will need to either:
A)Remove the Y-pipe.
B)Seperate the Radius arm bracket(s) from the frame.
THE issue with getting the trans out is clearance between the
bottom of the floor, the Y-pipe and the radius arm crossmember.
Removing any one of the three makes getting it in an out fairly straight forward
BTW, DO NOT attempt to remove the trans without
unbolting the Torque converter from the flex plate
and pushing it back into the trans.
It is not possible to remove the trans with the torque converter
bolted to the flex plate.
You access the torque converter bolts through either the inspection hole in the
dust shield OR through the starter hole..
Have fun....
AllanD
Old May 18, 2005 | 11:08 PM
deronyv8's Avatar
deronyv8
any one know how much it weighs? over 300 pounds? thanks
Deron
Old May 19, 2005 | 12:17 AM
AllanD's Avatar
AllanD
the T-case weighs about 75lbs
The trans about 150lbs
do not pull them together.
AllanD
Old May 19, 2005 | 01:58 AM
rebturtle's Avatar
rebturtle
You can pull/install it a lot easier with a ratchet-strap (see picture). I've changed the trannie several times by myself. With the strap, ingenuity, cursing, and a floor-jack, it can be bench-pressed alone. With two people it shouldn't be too bad. Try to lift the truck as much as you (safely) can and rest it on jackstands.
Old May 25, 2005 | 08:06 PM
deronyv8's Avatar
deronyv8
thanks guys. pulled it out with no trouble.
deron
