Thickness of 352 flywheel
C5AZ-6375-K .. 352/360 Flywheel / Use with 11" Clutch / Fits: 1965/67 F100/350 352 / 1968/76 F100/350 360 / 1965/67 Galaxie/LTD 352.
Marked: C5AE-6380-J / 184 Tooth Ring Gear / (6) 5/16" pressure plate attaching holes on a 12 3/8" bolt circle.
Jim, I just went through this. Had mine resurfaced for what I believe was the first time at just over 100,000 when I replaced the clutch (worn, oily). Are you finding insufficient adjustment under the truck? Here was my solution: I bought a section of all-thread and a threaded 'sleeve'. This may actually be a bit difficult as the threads on the original parts are fine thread, and most places only stock coarse. Thank you, well-stocked local hardware store. I cut a length of all-thread and used that between the fork 'pin' and the sleeve. Then threaded the eyelet rod from the Z bar into the other end of the sleeve. The sleeve winds up being longer than the length needed to take up the slack, so unfortunately the eyelet rod needs to be shortened. Not a real problem though, as the new arrangement gives you a ton of adjustment for later in life.
zoomeroo
19
07-07-2007 12:45 AM
tired67f100
11-26-2005 11:45 PM
Tony G
08-18-2004 09:51 PM
