stick shift
Old Jan 26, 2000 | 09:07 PM
chancewolf's Avatar
chancewolf
stick shift
I own a 94 f-150....the problem I have is as if I have no first gear left or something...My stick shift is not holding it's position and falls to the side when I try to put it in first or 3rd
goes into 2nd, forth and fifth ok..
any suggestions???
Old Jan 27, 2000 | 01:23 AM
SPLabar's Avatar
SPLabar
stick shift
Try to twist the shifter like a ****(right and left). Also pull up and down on it. If it wobles alot and feels like the shifter is going into the AC vent when you put it in first gear, then you have some work to do. The shifter has a ball on it that rides in two plastic cups in the top part of the housing. These cups wear out and break and fall into the tranny, leaving your shifter sloppy. The shifter also pivots on two steel pins staked to the case. One of mine worked its way out and caused a problem simular to yours. You will have to pull the tranny to replace it though. Replace the boot/dustcover, gasket, and silicone the three rubber pugs into the rear of the shifter housing or you will be gauranted a leak.
Steve
Old Feb 22, 2000 | 04:24 AM
budfrog's Avatar
budfrog
stick shift
i dont know how many miles you have on the tranny, but the shift rails inside it may be just worn out. mine did this at around 160,000 miles. i started noticing it wouldnt disengage from first or third, then it wouldnt go in at all.
Old Feb 22, 2000 | 07:39 AM
TallPaul's Avatar
TallPaul
stick shift
FordF-250Kid
May 16, 2014 04:38 PM
lakewood
Oct 7, 2011 08:18 PM
SagebrushRR
Jul 25, 2010 07:58 PM
640 CI Aluminum FORD
6.7L Power Stroke Diesel
75
Sep 7, 2009 04:28 PM
tholt34
Dec 14, 2006 08:19 PM
