Bending push rods
Old May 29, 2005 | 10:13 AM
  #46
Kwikkordead's Avatar
Kwikkordead
Originally Posted by Wellcraft
Is there 2 oil systems.. Low and high???????????
Not on an IDI engine. The HPOP is for driving the injectors on the DI motors.
Old May 29, 2005 | 10:43 AM
  #47
barebackjake's Avatar
barebackjake
the low pressure system is the lube system which feeds the lifters
the high pressure system only operates the injection system.
did you replace the hold downs for the lifters also??
5.7kg sounds about good on the oil pressure where are the senders at???
i would be suspect of the oil pressure relive valve also. you can take it apart and look at the bore to see if its scored or a groove wore in it or if theres a chunk of crap stuck in it.
Old May 29, 2005 | 10:47 AM
  #48
barebackjake
oh this is on a IDI motor???
hmmmmmmmmmmmmm still think the pressure relive valve. its mostly only doing it to exaust valves timing gears??? i bet thats been covered....
Old May 29, 2005 | 12:32 PM
  #49
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
The engine have 2 oil pressure gauges on it.. One reads 5,7 kg and the other one is reading 2,7 kg
We didnt clean anything.. It looks like unused inside the engine.. But what we cant see??? Dont know.
Thinking of the oil pressure bypass valve sitting in the block left side on top. Can this be cleaned??
Here is a picture. Parts from 14 tru 18
That's not a bypass valve. It's an anti-drainback checkvalve that prevents the high pressure oil reservoir from draining. If it were bad the engine wouldn't start. I don't think the lube oil system is the problem. I think it's defective hard parts, either the lifters or the rocker arm and I'd put my money on the rockers.
Also, from an earlier post, the copper colored ends of the pushrods go up, and the engine needs to be rotated until the mark on the crank damper is at 11 o'clock for rocker arm installation to prevent bending valves.
Old May 30, 2005 | 12:46 AM
  #50
Fis Teck's Avatar
Fis Teck
Make sure you have the correct head gaskets.
Old May 30, 2005 | 04:06 PM
  #51
Wellcraft's Avatar
Wellcraft
Is there different types... Mercruiser cant help us here in Norway.. They cant find out why its bending pushrods..
I will look into the rockers
C_thetroll
26
Aug 18, 2016 04:49 PM
waco1313
Dec 7, 2015 10:25 PM
240inline
Dec 1, 2015 02:12 PM
brownie83
Oct 10, 2011 06:50 PM
rogerlc
Jan 13, 2009 12:28 PM
