Strange Happenings..
Old May 22, 2005 | 11:51 AM
styln's Avatar
styln
Several months ago I got codes p0135 and p0155 show the heated o2 sensors were bad. I thougt it strange they both would go bad at once..but I replaced them both anyways. The check engine light didn't go off and I still get the codes after reset.
Now, The speedometer bounces up and down, the radio only works when the vehicle is in Park or Neutral, and the OD light flashed. At times after the truck is shut off the engine shuts off, but all the accessories stay on and you have to turn it on and shut if off again. Also while driving sometimes it will start beeping, five beeps, pause, five beeps, pause for a few minutes.
I now have P0500 which is the speed sensor. I checked the forums and it sounded like an easy fix. I got a sensor, replaced it.. No change.
Any ideas?
Thanks,
Old May 23, 2005 | 07:10 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old May 23, 2005 | 02:34 PM
Monsta's Avatar
Monsta
Sit. Stay.
Sounds like the GEM is fried...or it could be shorts within the PCM...OOOOOORR it could be....SATAN!!
Welcome to FTE!
Those problems are definantly related to a faulty GEM.
Old May 25, 2005 | 11:50 AM
ppodojil's Avatar
ppodojil
What is a the GEM? I have not heard that abreviation before.
Old May 25, 2005 | 03:39 PM
Monsta's Avatar
Monsta
Sit. Stay.
Generic Electronic Module
Old May 26, 2005 | 02:09 PM
wipper's Avatar
wipper
you might want to check the wiring harness they lay on the fender and ware through the wires that was what was wrong with my o2 sensors
greatone111
2004 - 2008 F150
13
Jan 9, 2020 08:58 PM
proudfrog
Mar 28, 2016 12:14 PM
07fx4150
Modular V8 (4.6L, 5.4L)
Feb 24, 2016 02:09 PM
daveclow
Oct 11, 2014 10:31 AM
pabear89
Escape & Escape Hybrid
Aug 24, 2011 12:57 PM
