fipl
Old May 21, 2005 | 09:17 PM
chefandy1st's Avatar
chefandy1st
fipl
Just a question? Does the fipl look like a flat plate on the side of the tranny with about 8 wires comeing out of the top? If so I have read the post on how to reset the fipl but I can not find a grey and white wire any other color I should be looking for?
1991 F350 7.3l
Thank you
Old May 21, 2005 | 11:49 PM
Dave Sponaugle's Avatar
Dave Sponaugle
The FIPL is located on the Injection Pump throttle linkage.
Fuel Injection Pump Lever position sensor to control the automatic transmission.
Old May 22, 2005 | 05:54 AM
trike1946's Avatar
trike1946
On my 90 it is locater right in front of the fuel filter, hanging on the side of the IP pump. It has three wires coming out. Do a search on TPS and you will find some good info. If you have problems post back or email me, I think I have a picture somewhere. Good luck with it.
Old May 22, 2005 | 07:37 PM
chefandy1st
Thank you just found the fipl and the wiring harness came off, of all the dumb things that could have happened. Just plugged it back in and it runs smooth. Thank you again
Ken
Old May 23, 2005 | 05:25 AM
trike1946's Avatar
trike1946
If the clips are broken that hold the plug on use a wire tie to secure it. Mine came off while towing and overheated the trans.
FORDF250HDXLT
117
Feb 10, 2025 11:29 PM
Powerstroke-7.3
May 27, 2011 10:24 AM
bleedin blue
Feb 2, 2008 07:29 PM
dakotajeep
16
Jan 26, 2008 10:45 AM
Gambler
Dec 18, 2002 11:52 AM
