Need help!! on FIPL
Old Dec 15, 2002 | 03:53 PM
Gambler's Avatar
Gambler
Need help!! on FIPL
I have an error code and need to know where to find the FIPL on a '94 idi turbo diesel.
Thanx, Gambler
Old Dec 16, 2002 | 06:11 AM
bilder12's Avatar
bilder12
Need help!! on FIPL
Is that not the switch on the injection pump that controls the shifting of the transmission? If so it is on the drivers side of the injection pump and moves with the throttle lever.
Old Dec 16, 2002 | 07:50 AM
79CEEJAY's Avatar
79CEEJAY
Need help!! on FIPL
OK, sounds kind of crazy...but in the past when I have gotten a code and had no idea where the faulty part was...but knew it was faulty, I would go ahead and buy the part then just look for it on the engine. Then go ahead and replace it. I know this sounds crude, but my '90 F-250 had so much spaghetti under the hood, it was difficult to track down some of the parts...especially the emissions related parts....without a book that many times I would just but the part then match it up...believe it or not it worked most of the time. :-X12
Old Dec 17, 2002 | 10:12 PM
Gambler's Avatar
Gambler
Need help!! on FIPL
Is it the switch that has a plug with 3 wires on it or is it on top of the injector pump with two spade lugs sticking up with snap connectors?
Thanx
Old Dec 17, 2002 | 10:49 PM
argve's Avatar
argve
Need help!! on FIPL
I replied to you orginal post, have not been on here in a little while.
Old Dec 18, 2002 | 07:34 AM
bilder12's Avatar
bilder12
Need help!! on FIPL
I believe the part you are looking for is on the drivers side of the injection pump mounted where the throttle shaft comes thru the pump housing. It rotates internally and acts like a switch, indicating the position of the throttle.
Old Dec 18, 2002 | 11:52 AM
TurboTuff's Avatar
TurboTuff
Need help!! on FIPL
FORDF250HDXLT
117
Feb 10, 2025 11:29 PM
Rat77
53
May 30, 2012 05:00 PM
91_diesel_7.3
Jan 16, 2010 07:34 AM
Lukkys
Sep 26, 2009 01:23 AM
Gambler
Dec 18, 2002 03:23 AM
