Torque wrench types: Click -vs- Scale
Old Sep 15, 2001 | 06:56 PM
Greywolf's Avatar
Greywolf
It has always seemed to me that click-type torque wrenches are both more expensive, and designed for assembly-line uses.
My preference is to use a beam-type scale readout, because I can hold a fixed torque on a fastener long enough to make sure it has set at the specification I want it to.
With a click type, as soon as the click comes we back off on the wrench. I feel that a scale readout allows me to maintain the correct amount of force long enough for bolts to properly take a "set", helping the overall strength of the pieces I use it on.
I have found them especially useful on intake manifolds. And in fact, I just finished an Edelbrock installation.
Intakes can be funny critters at times, this way I have less repeat torque checks to do...
Old Sep 16, 2001 | 06:50 AM
lastchance's Avatar
lastchance
I've always trusted click type torque wrenches more. Depending on where you have to stand to pull on them and how hard you are pulling you may have a difficult time seeing the beam and scale on the meter of a beam type torque wrench. Plus if you don't look at it the same exact way everytime, you won't be reaching the same torque anyway. As I approach the spot where I feel my torque wrench is gonna click I pull as slow as I possibly can. I'll usually run back over all the bolts in the proper torque sequence and give them another slow, steady click to make sure they are all even. In my opinion the click type are much more acurate.
Old Sep 16, 2001 | 07:48 PM
Tomohawk1's Avatar
Tomohawk1
I've always heard that the scale type were cheap imatations of torque wrenches and are 100% unreliable. i've always trusted the click type wrenches as they withstand more torque than a scale type. Ofcourse, thats just my opinion.
Old Sep 16, 2001 | 08:58 PM
Ultramagdan's Avatar
Ultramagdan
I'll take a click type most days. It seems to be more "stable" while the scale seems to flex more. For very low torque, a scale is fine. But for anything over 20 lbs, the click is hard to beat. Besides, you don't have to look at a click, you can feel it coming and then Click!
98 F250LD 4X4
Slotted Rotors
Old Sep 17, 2001 | 04:59 PM
razookelly's Avatar
razookelly
I have both types of torque wrenches, and I use them both. However, I use the click type for serious building. I believe it to be more accurate.
Good Luck.
Old Sep 17, 2001 | 05:51 PM
otto's Avatar
otto
I use a Snap On Torqometer dial type toque wrench and a click type, they both work well
Old Sep 17, 2001 | 06:31 PM
whomrig's Avatar
whomrig
I have usually preferred the click-type also.
Wayne 60 F-350
e-mail
http://home.pacbell.net/whomrig
Old Sep 19, 2001 | 06:26 AM
razookelly's Avatar
razookelly
Old Sep 19, 2001 | 05:24 PM
theologian's Avatar
theologian
I am an Aussie, and had never seen a guage type until I came here, I have always used the click type.
Wm
'96 F450 Custom Crewcab 4x4 Flatbed, Powerstroke, Banks Powerpack, Chip, Tranny control,Aux tranny, engine worked giving 340 hp and 660lb ft torque
Old Sep 21, 2001 | 08:18 AM
Greywolf's Avatar
Greywolf
To each their own preference, I suppose.
I had, at one time, a snap-on micrometer-adjustable clicker. It bothered me when I began to see "creep" on bolts though -
The second time around, even on bolts that had just been done, I found the wrench moved a little further.
A click type CAN be used to check the accuracy of a scale...
But when was the last time you had your wrench calibrated?
Hmm....
Could be a point, where and when to have them checked....
ford2go
Dec 16, 2011 01:32 PM
TexasGuy001
Feb 3, 2009 08:51 AM
bf250
Oct 9, 2006 03:14 PM
