Sponsored by: Auxito
ac/ deforst????
Old May 18, 2005 | 09:38 PM
jason gressley's Avatar
jason gressley
ac/ deforst????
My 2001 4x4 f150 supercrews ac has been switching from ac to defrost when I accelerate and kicks back to blowing out the vents when the motor levels out. Has anyone had this problem and if so what was the fix.
Old May 19, 2005 | 02:55 AM
MrBSS's Avatar
MrBSS
Defrost is the default position. You have a vacuum leak. First place to look is probably at the control panel.
Old May 20, 2005 | 06:48 AM
projectSHO89's Avatar
projectSHO89
Actually, the best place to look is under the hood. There is a small black plastic vacuum line that is routed between the battery and the firewall (it then goes through the firewall) that is a common failure.
Inspect the line. If a leak is found, the bad section can be cut out and replaced with a short length of bulk rubber line that is available at any auto parts store. Just take a short section of the plastic line into the store with you nad test fit it into the rubber hose to make sure you get the correct size.
Steve
Old May 20, 2005 | 11:01 AM
MrBSS's Avatar
MrBSS
That's the best part about this forum: Somebody has usually seen your exact same problem on the exact same vehicle.
Old May 20, 2005 | 08:28 PM
dlorenz's Avatar
dlorenz
Yup - had this same problem - the vacumn resorvoir is behind the battery holder and the hard vacumn line passes within a few inches of the battery on the firewall side - get a little battery acid on it over time and it gets hard, cracks, and eventually breaks.
Old May 22, 2005 | 05:51 PM
jason gressley
thanks for the help i will check the vacuum tomorrow
410F-100
1997 - 2003 F150
Oct 27, 2012 06:40 PM
MtnGoat
1997 - 2003 F150
Aug 4, 2012 04:49 PM
RTM
Jul 16, 2009 04:15 PM
DGMFORD
Nov 21, 2008 12:03 PM
Brochure
Dec 14, 2002 03:56 PM
