AC clutch cycling problem - 96 Explorer
Old Nov 30, 2002 | 01:19 PM
Brochure's Avatar
Brochure
I have a 96 explorer 4.0L and the AC clutch keeps short cycling when the AC is not on. Even when the heater is on. Has anyone else run into this problem also?
Old Nov 30, 2002 | 08:24 PM
samhihn's Avatar
samhihn
The compressor will come on when the heat is in the defrost mode. This is true on most newer cars and trucks. Check your owners manual for specifics for your year vehicle.
Old Dec 11, 2002 | 01:04 PM
LarryC64's Avatar
LarryC64
Post AC clutch cycling problem - 96 Explorer
I have the same problem with a 96 Explorer. ac clutch engages & quickly disengages when heat is on & vent position switch is not in defrost position.
Old Dec 12, 2002 | 06:26 PM
hrbib21's Avatar
hrbib21
Old Dec 14, 2002 | 03:56 PM
Brochure's Avatar
Brochure
Larry, I decided for the time being that I would just disconnect the power cable to thre compressor. I know that this is not a solution, but until we get some other response, it will have to do.
VA250SD
May 12, 2012 11:58 AM
VA250SD
Aug 9, 2011 12:08 PM
1998Ranger25L153CID
Jun 18, 2007 11:00 PM
mfcarpino
Sep 8, 2005 04:31 PM
