Sponsored by: Auxito
A/C siezed up
Old Aug 3, 2012 | 01:34 PM
MtnGoat's Avatar
MtnGoat
A/C siezed up
A friend of mine has a 1998 f-150 4x4 with a 5.4 v8. He stopped by the house yesterday and when he went to leave the truck wouldn't turn over. The A/C compressor bearing seems to be frozen and wont let the motor turn. Is it possible to bypass the a/c unit using a belt from a non a/c truck? or is it a bit more complex than that. Also is it possible to just replace that bearing rather than toss out a perfectly running compressor?
Thanks in advance for any help
Old Aug 3, 2012 | 04:41 PM
projectSHO89's Avatar
projectSHO89
Probably, just the pulley bearing fail. Been there, done that, got the ride home on the flatbed with my old 5.4L 97 F150.
To verify, remove the serpentine belt and see if the engine cranks. If it does, shut it down and check the compressor pulley by hand.
The pulley and clutch can be replaces with basic hand tools plus a 90 degree inside snap ring pliers. It's not hard. I did mine in 30 minutes in the gravel driveway. Hardest part is getting the darned snap ring to cooperate.
Recommend you use Motorcraft parts instead of the cheap stuff from who knows where.
Old Aug 4, 2012 | 04:49 PM
MtnGoat's Avatar
MtnGoat
Projectsho thanks for the reply. Of course nothing is ever that easy, I removed the compressor and found the clutch was toast. The front bearing came out in several pieces and the rear bearing is also no good. So it is off to the junkyard for a replacement.
Cor
2004 - 2008 F150
Mar 31, 2015 03:29 AM
Galen
19
Jun 22, 2011 11:44 PM
RhinoScores
Jun 6, 2010 05:28 PM
gmcco
Apr 9, 2009 12:50 PM
manasota
Aerostar
May 6, 2005 11:12 AM
