Installing a tachometer
Old Nov 5, 2012 | 01:51 PM
  #31
1986F150six's Avatar
1986F150six
It appears that some low reving [4000 / 4500 rpm] tachometers were used in large trucks [F600] with gasoline engines. Most that I have seen [on forums] are 4000 rpms. On the back, they have the same four terminals as the 6000 rpm gauges shared by 6 cylinders and V8s.
The diesel tachs will not work with the gasoline engines [I tried]. Instead of getting their signal from the 12V @ the coil, the signal is in millivolts and is supplied by a sending unit specific to the diesel engine. I am not certain, but believe it may be driven by the injector pump?
If anyone runs across one of the 4000 rpm units, PM me as I would be interested.
Old Nov 5, 2012 | 01:53 PM
  #32
1986F150six
Originally Posted by 85Blondie
I have a 85 Inline 6. It originally did not have a tach, but I bought a gauge cluster out of a 80s F-350 that had one. Anyhow, because my truck never had a hook up for a tach would I be able to install one? And if so how would I go about doing this?
I included some pictures of my new dash.
Thanks!
If the photo is of the "new" cluster, did your truck originally have the gauges or "idiot" lights?
82fordowner
Apr 8, 2013 02:54 PM
crestfallinman
Sep 28, 2011 09:01 PM
imlowr2
18
Mar 25, 2006 10:41 PM
Nightrain
Jun 5, 2004 07:47 AM
oft
Aug 7, 2002 02:50 PM
