I got a 82 f100 stepside I have the gauge cluster out it has the tach installed but there is no circuit running over where the tach goes. Can I just put in the circuit for the tach installed and have it work or is the wiring different! I don't understand why it has the tach installed but no circuit for it to work. And where can I find the printed circuit for the tach in my 82?
I have an old instrument cluster out of an '85 with a tach. I am pulling the ammeter for another member here. I would be happy to send you the printed circuit if you want. It says on it E1TF-10C956-B if that helps at all. It has 9 strips top and bottom where the harness connects. 0-6000 rpm gasser tachometer unit.
Yes Ford F834 I can give it a try what do you want for the circuit? I am a newer user so I don't know if I can email you my address other wise I can just post it here. We can get together to figure it out Thanks Fred
I sent you a pm, with my regular e mail in case you can't reply to it. No charge for the part, just members helping members. Many have done so for me!
