Tach install
Old Jul 27, 2002 | 01:44 AM
oft's Avatar
oft
Tach install
I'm installing a VDO tach on my 78 w/a 351W. On the negative side of the coil, there's a green wire that runs to the trucks brain box. Do I splice my tach onto this wire?
Jayson
Old Jul 27, 2002 | 01:54 AM
Torque1st's Avatar
Torque1st
Posting Legend
Tach install
That green wire on the negative side of the coil is the usual place. You must follow the directions that came with the tach.
That "brain box" doesn't have much of a brain, it is the ignition module.
Old Aug 3, 2002 | 11:03 PM
Fordman54703's Avatar
Fordman54703
Tach install
What I do is using a connector and hit right on the coil if have the plug on it I just rap the wire around the post and snap the plug back on the coil. Worked great on my 79F150
Old Aug 4, 2002 | 07:44 PM
85351ho's Avatar
85351ho
Tach install
what they said
Old Aug 6, 2002 | 04:59 PM
oft's Avatar
oft
Tach install
All,
Intalled the tach but I'm not sure if it is operating properly. Says I Idle around 800 RPM which sounds right. I have not changed my driving style, the tach tells me I shift between 2-3 grand. At what the tach says is three grand really sounds like I'm pushing it, it wont rev much higher. I thought a V8 should redline around 5 grand (my mustang redlines at 5500) Is this something to do w/the trans?
Mine is a 351W witha 3 speed manual trans
Old Aug 6, 2002 | 11:55 PM
Torque1st's Avatar
Torque1st
Posting Legend
Tach install
No, nothing to do with the trasmission. Have you got all of the switches or jumpers set right?
Old Aug 7, 2002 | 10:32 AM
oft's Avatar
oft
Tach install
The only setting I saw on it was a 4-6-8. I set it to 8. Anything I'm missing here?
Jay
Old Aug 7, 2002 | 10:46 AM
BB's Avatar
BB
Tach install
What gears and tires do you have and what do you tach at 60mph?
Barry
Old Aug 7, 2002 | 02:50 PM
captkane's Avatar
captkane
Tach install
Sandracer340
Aug 31, 2015 06:56 AM
mrbison
19
Jun 1, 2015 10:24 PM
Handegard
Feb 22, 2014 11:27 AM
Old Hickory
Feb 26, 2011 08:39 AM
charles jones
Jan 7, 2006 07:59 PM
