C6 TO AOD
Old Jan 8, 2000 | 03:15 PM
Hanky's Avatar
Hanky
C6 TO AOD
I would like any info on making this swap. My Truck is a 1989 f150 4x4 4.9 ltr 6 and I have purchased a 89 aod tranny, the bell housing, flex plate, torque converter, and both front and rear drive shafts. I am having trouble finding a trottle valve cable , the nuetral safety switch harness and the manual likage from the frame to the tranny. Any tips would be appriciated. Is there any way I can get by with some modified linkage or is there a kit sold by someone to make this easy.
Old Jan 8, 2000 | 05:44 PM
StrangeRanger's Avatar
StrangeRanger
C6 TO AOD
Check with Art Carr at <a href="http://www.artcarr.com">http://www.artcarr.com</a>/ he is the guru on all things AOD relatyed
Old Jan 26, 2000 | 12:00 PM
SPLabar's Avatar
SPLabar
C6 TO AOD
Keep your c-6 its a tuff tranny. The aod is easy to tear up. We rebuild the ones in our work trucks after 60,000 miles or so and it costs a couple of thousand each time depending on what it tore up. You can use bothe transmisions though, you can take the fist gear out of one and put it into the other, to make it lower. I dont remember if it aod into c-6 or the other way around. Any way if you find a transmision shop that even knows it is possible they will know which way it goes.
Old Jan 26, 2000 | 05:35 PM
slikness's Avatar
slikness
C6 TO AOD
Check into the B&M Megashifter, it should resolve any linkage problem and moves the neutral safety switch to the shifter column.
Check with Lokar for the TV cable. They have a lot of setups that can be tailored to your application.
And I agree that you should really keep your C6; it's a tough tranny.
'82 F150 w/351W (orig 300 I6)
Slik
Old Mar 20, 2000 | 12:01 AM
Nate_64's Avatar
Nate_64
C6 TO AOD
Old Mar 20, 2000 | 03:52 PM
Reuel's Avatar
Reuel
C6 TO AOD
If you still have the C6, I need one. How much you want for it?
Old Mar 26, 2000 | 06:58 PM
Whiskers's Avatar
Whiskers
C6 TO AOD
I would check your differential ratio carefully before this swap. The AOD is usually used in conjunction with a lower ratio gear than the C6.
onioncasserole
Oct 18, 2007 07:39 AM
dtchiller
Jul 8, 2007 07:45 AM
Icicle
Feb 28, 2005 05:34 PM
muscletruck7379
Aug 1, 2004 10:28 PM
