aod to c6?
Old Apr 1, 2000 | 09:33 PM
fordconvertie's Avatar
fordconvertie
aod to c6?
I have a 90f150. It was bought without a transmission and am thinking of putting in a c6. It originally had an aod and manual shift 1356 tcase. Does anyone know if a c6 will bolt to the 1356 that was on the aod? Does the aod and c6 have the same spline count? Also, I was wondering what axle gears are usually used for stock c6 transmissions?
Thanks,
dan
Old Apr 1, 2000 | 11:19 PM
Katt's Avatar
Katt
aod to c6?
Only help I can offer is that the BW 1356 should bolt to the C6 just fine.
Old Apr 2, 2000 | 01:44 AM
PAUL_2's Avatar
PAUL_2
aod to c6?
Old Apr 2, 2000 | 08:31 AM
DeenHylton's Avatar
DeenHylton
aod to c6?
Dan, I believe the AOD is longer than C-6 so some driveline lengths will also need to be changed. You did not say what engine you have or what you use your truck for (towing, hard off-road, etc.)My feeling is you wouldn't want a 4WD unless it had at least a 3:55 or 3:73 gear. From all the posts I've seen on problems with the overdrive units your making a good choice to go to a C-6. Deen
mean green 91
Apr 25, 2011 06:35 AM
helirich
1978 - 1996 Big Bronco
May 10, 2010 10:24 AM
witdog2020
Jan 9, 2006 07:47 AM
ClatonK
Mar 4, 2005 06:58 AM
grago87
Sep 21, 2002 07:51 PM
