Gear Identification
Old Apr 1, 2000 | 09:58 AM
Katt's Avatar
Katt
Gear Identification
I have the third member out of my dana 44 IFS and would like to find out what ratio it has. I found a bunch of numbers/letters that are on the ring gear, but none look like a ratio. Is there a code to it?
Thanks
Old Apr 1, 2000 | 12:09 PM
Katt's Avatar
Katt
Gear Identification
Here are the numbers that are on the ring gear:
11 12 80 DANA 0 37259 A30128 42 12
Thanks for the help!
Old Apr 2, 2000 | 12:17 AM
CJay's Avatar
CJay
Gear Identification
If I remember correctly all you have to do is count the number of teeth on the pinion gear and on the ring gear then multiply them and that will give you your ratio.The number won't always come out to be the most commonly known gear ratio axample-if the numbers multiply to be 352 you actually have 3:55.
Old Apr 2, 2000 | 01:44 AM
PAUL_2's Avatar
PAUL_2
Gear Identification
Its simple ...if you know your rear axle ratio , the front has to be the same .
Paul
Old Apr 2, 2000 | 08:16 AM
DeenHylton's Avatar
DeenHylton
Gear Identification
>have to do is count
>have 3:55.
Actually you want to DIVIDE the ring gear count by the pinion tooth count.
Old Apr 2, 2000 | 12:38 PM
VanMan's Avatar
VanMan
Gear Identification
you have a 3.5:1 gear set. If you count the ring gear you'll see you have 42 teeth and on the pinion gears you'll have 12 teeth. Divide the 42 by 12 and you get 3.5 If you notice, these #'s (42 12) are ones you posted. Alomst always, the front gears are a "little" different ratio from the rear. i.e. 3.55 & 3.50
Old Apr 2, 2000 | 01:09 PM
Katt's Avatar
Katt
Gear Identification
Thanks for all the help everyone!
Old Apr 2, 2000 | 03:57 PM
Pizza's Avatar
Pizza
Gear Identification
