C6 to AOD
Old Sep 18, 2002 | 05:14 PM
grago87's Avatar
grago87
C6 to AOD
I'd like to from the C6 to the more fuel economic AOD. does anyone have or know where i can find specs on them? what will it take to make the swap happen? it is a bronco with a 302 and a BW 1356 transfer case.
thanks
Old Sep 20, 2002 | 02:21 PM
DoubleA's Avatar
DoubleA
C6 to AOD
I helped a friend do that swap on his truck.
When using a 4x4 tranny, it bolts up to the xfer case, use AOD torque converter and it bolts up to the C6 flywheel.
the AOD is only about 1/2" longer so the stock mount can be used.
The shift lever was different, the tranny we used came from a car so a truck one might be different, but I just welded an extension on the tranny arm to make it work.
We used a Lokar TV cable, it worked pretty good.
Bolt it up and set up your TV pressure (0-5 psi at idle)and your off.
Old Sep 21, 2002 | 11:02 AM
deere81's Avatar
deere81
C6 to AOD
If you do the swap, do not use a C-6 flywheel. It will damage your tranny. Make sure you get an AOD flywheel. The C-6 and E4OD use one flywheel, but AOD and C-4 use another flywheel.
'90 F-150 351 AOD "The General"
'78 F-250 460 C-6 "Old Green"
'93 Mustang 5.0 AOD
'88 Jeep Cherokee 4.0
Old Sep 21, 2002 | 07:51 PM
oregon250's Avatar
oregon250
C6 to AOD
miashley150
Mar 18, 2013 06:40 PM
88dually
20
Feb 26, 2013 09:38 PM
shane1
Jan 31, 2005 02:43 PM
nechun
1978 - 1996 Big Bronco
Dec 3, 2003 09:13 PM
