Linkage
Old May 15, 2005 | 12:31 AM
TheGeneral78's Avatar
TheGeneral78
Linkage
Im putting a Holley 650 4 Barrel on my 351M and the linkage thats on the truck is not going to fit the new carb. Im sure there are plenty of yall that have done a similar swap and have an easy fix. Do I have get a new linkage or can I modify mine to work? I concidered cutting the ends off of both the linkage that I got with the carb and the one thats on the truck and welding/sleeving the two together that would work, this is only a last resort though and Im pretty sure theres a better option out there. Thanks for all yall's help. this is my first carburated V8 so forgive me If im unimformed.
Old May 21, 2005 | 11:23 AM
stretch351c's Avatar
stretch351c
Why not just go get a cable throttle linkage instead? It would probably be faster and a lot more reliable. I think some of the newer Ford trucks used them so you could find the brackets and other stuff to mount it on one of them.
Old May 24, 2005 | 12:03 PM
voodoosurfer's Avatar
voodoosurfer
I used a 24" lockar cable for mine with the ball stud attachement at the carb cost around $35.
Old May 24, 2005 | 01:54 PM
jleinweber's Avatar
jleinweber
Holley also sells a kit for the Ford throttle ball attachment, and also sells a kit for the kickdown rod.....
PapaBearYuma
16
Feb 21, 2017 10:13 AM
mastapasta
18
Oct 17, 2016 02:27 PM
Anthonyp55
27
Dec 29, 2015 03:58 PM
55fordf100Gramps
Apr 11, 2013 06:20 PM
jaspirr
Mar 5, 2010 11:01 PM
