Carburetor Linkage Issues
Old Oct 15, 2016 | 05:42 PM
mastapasta's Avatar
mastapasta
Hey all,
I own a 1971 Ford F-250 Custom that I'm currently working on, and I'm having a load of issues with my carburetor linkage.
It is extremely fragile. Half of the time when trying to start my truck, it will break, and I will have to affix a new one to get going.
It drives me insane. When I'm trying to fix starter issues, I have to halt all progress to fix the carburetor linkage.
I've gone through too many, and am looking for help now.
Do you guys know where to find a good quality carburetor linkage (that won't break when I use the throttle), or any solutions to make sure it doesn't break?
Any feedback is appreciated!
Old Oct 15, 2016 | 09:51 PM
85e150's Avatar
85e150
Welcome to FTE.
OEM throttle linkage is pretty strong stuff. Is this OEM linkage?
Is your linkage adjusted so that when the pedal is on the floor, the throttle blades are wide open? If you are wide open before the pedal is floored, you will have a lot of stress on things.
Is it cable linkage or rods?
A thread on the subject along with a spiffy illustration:
https://www.ford-trucks.com/forums/9...tock-carb.html
Old Oct 16, 2016 | 05:37 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Throttle or choke?
Old Oct 16, 2016 | 10:15 AM
mastapasta's Avatar
mastapasta
Originally Posted by Krewat
Throttle or choke?
It is the throttle.
Old Oct 16, 2016 | 10:21 AM
mastapasta's Avatar
mastapasta
Originally Posted by 85e150six4mtod
Welcome to FTE.
Sadly, no, it is not OEM linkage. My usual suppliers don't have the linkage for some reason (either that or I'm too ignorant to find it). It is so weak that I can bend it with two fingers. It is the stock type of linkage, the material is just very weak and lasts a very short amount of time.
It is the rods.
Also, thank you for the link. The diagram on that page (http://www.fordification.com/tech/im...elinkage01.jpg) shows the part that is breaking, #9826.
I will check how the throttle is adjusted when I am able to as well.
Old Oct 16, 2016 | 10:28 AM
mastapasta's Avatar
mastapasta
I'm on full throttle about a half an inch before I'm flooring it.
Old Oct 16, 2016 | 10:30 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
I know what the problem is. What size is the engine, which trans does it have?
Old Oct 16, 2016 | 11:00 AM
mastapasta's Avatar
mastapasta
It has the 360 with the 4 Speed Syn. Warner T-18 trans in it.
Old Oct 16, 2016 | 11:20 AM
NumberDummy
1967/72 F100/350's with V8 engines have a bellcrank that bolts to the rear of the intake manifold, the carburetor rods attach to it.
The problem is that the bellcrank has nylon bushings that crack apart, they cannot be replaced by themselves, so...when this occurs, the carb rods flop around.
D0TZ-7A185-A .. Bellcrank / Obsolete
1970/72 F100/350 360/390.
NOS PARTS SOURCE in Olathe KS has 1 = 913-220-5746.
MILLER OBSOLETE PARTS in Binghamton NY has 2 = 607-722-5371.
OBSOLETE RELIABLE PARTS in Nashville GA has 3 = 229-686-5101.
NOS PARTS LTD in Waxahachie TX has 4 = 972-937-2201.
Bellcrank shown as 7A185 in upper pic:
Old Oct 16, 2016 | 01:31 PM
hiball3985's Avatar
hiball3985
You said your problem is with #9826. that's just a spring clip, is that correct?
Old Oct 16, 2016 | 05:04 PM
mastapasta's Avatar
mastapasta
Yes, it goes by several different names on different distributors, most call it a carburetor linkage, so that's what I call it.
Old Oct 16, 2016 | 05:08 PM
mastapasta's Avatar
mastapasta
But this causes the carburetor linkage to break?
Old Oct 16, 2016 | 05:52 PM
hiball3985's Avatar
hiball3985
It's just a spring retaining clip. who ever told you it's linkage doesn't know what they are talking about. Those clips come in left /right and different diameters. If you find the correct one your problem will probably go away. At most part stores you can buy a package with an assortment of them..
http://www.ebay.com/itm/like/152146518504?lpid=82&chn=ps&ul_noapp=true
Old Oct 16, 2016 | 07:21 PM
mastapasta's Avatar
mastapasta
Help Parts 41016 Carburetor Linkage Clip Assortment | eBay
That's what my issue is. The ones from part stores that are an assortment are extremely cheaply made and do not last. They shouldn't be easily bent, and can be bent with just two fingers. I've gone through tons of the ones in the link you sent me.
Old Oct 16, 2016 | 08:12 PM
mikeo0o0o0's Avatar
mikeo0o0o0
My parts catalogs don't go back that far, but if this is the clip you're looking for (C7TZ-9826-A), Green Sales in Cincinnati, OH has 182 of them (800) 543-4959.
I would also take a long hard look at the rest of your linkage. It sounds like there are other issues going on. Usually these clips are pretty trouble free.
