power window motor question
Old May 14, 2005 | 09:37 PM
mxzx's Avatar
mxzx
My power window motor needs replacement on my 97 expedition and my haynes manual gives a big warning to bolt the sector gear and and backing plate together or serious injury could result. Do you do this after you take the whole assembly out of the door and before you separate the motor from the regulator? I can't see where or how this is done while everything is riveted to the inside of the door panel?
What is the proper way to drill out rivets?
Thanks
Old May 18, 2005 | 09:15 PM
jroyalty's Avatar
jroyalty
Drilling out rivets
Don't know of a proper way, I used a small bit, then went to a bigger bit then pulled the rivet out with pliers.
Jim Royalty
1998 Tan XLT 4.6L (now being sooped up by son)
2004 Red XLT 4.6L
Old May 19, 2005 | 12:16 PM
pitrow's Avatar
pitrow
I have no idea about the window motor, but I've drilled out tons of rivets. I use a bit that is the same size, or just slightly smaller than the shank on the rivet. You can use a larger one too if you don't care about risking scratching the surface around the rivet. Drill through the head until the head seperates from the shank. Then pop the rivet out the backside.
Spktyr
Mar 17, 2013 12:46 AM
z1121jack
Aerostar
Jun 16, 2009 09:29 PM
jklumb
New Member Introductions
Mar 31, 2008 12:25 AM
Charger73400
1983 - 2012 Ranger & B-Series
Dec 30, 2005 10:31 PM
dburke8088
Nov 13, 2004 04:30 PM
