Bronco II Ford Bronco II
a4ld interal parts
Old May 14, 2005 | 07:53 AM
Monty06's Avatar
Monty06
Question a4ld interal parts
i'm looking for a new TC for my a4ld and a shift kit if there is one for my trans.
i was looking at a 94 explorer a4ld what would i need to do in order to make that trans work i know there is a difference in valve body solenoids.
anybody know any sites where i can find parts.
thanks guy in advance.
Old May 14, 2005 | 08:35 AM
oppy's Avatar
oppy
Try eBay. I have seen Transgo kits on there very reasonable.
Old May 18, 2005 | 01:12 PM
orlysan's Avatar
orlysan
There is a company called Transmission Exchange Company out of Portland, Oregon that I have used numerous times for A4LD parts. They also have shift kits. Their telephone number is 800-776-1191 and their web-site is www.txchange.com
They have always been able to help me and have often been able to provide me with good used parts rather than new ones. Their service has been great for me.
Old May 18, 2005 | 04:47 PM
mrshorty's Avatar
mrshorty
"i was looking at a 94 explorer a4ld what would i need to do in order to make that trans work i know there is a difference in valve body solenoids." -- The major practical difference (as far as fitting it in) between a '94 4.0 A4LD and an '87 2.9 A4LD is in the 3-4 shift control. On an '87, 3-4 shift is vacuum controlled. On a '94, it is electronically controlled. The main thing you would need to do to fit a '94 A4LD behind your '87 2.9 is devising some way of commanding the 3-4 shift. I've heard of "pressure" switches that can command the 3-4 shift based on engine vacuum. I would also consider just commanding it manually (with a toggle switch).
fixerupperb286
Bronco II
Jun 3, 2012 03:51 PM
hammerhead27
Bronco II
Dec 28, 2007 02:48 PM
fordcomfortablynum0
Dec 13, 2006 12:13 AM
bhsmith
Sep 12, 2003 08:03 PM
