i have a ranger with a auto tranny. it came factory with out the tach. i would like to have one just for looks but fuctional. i want to mount it in the ac vent. is this i good idea to install ecven on a auto or a waste of money and time?
I like having a tach on my trucks even with an auto, If you like the way it looks go for it. Keep in mind you can get a used instrument cluster with a tach and swap that into your dash.
I don't know why tachs aren't STANDARD equipment, being as my swap-in has helped with diagnosis!
As for why I went factory, well, my swap looks factory as I swapped the center speedo section to keep the proper odo reading and less than $50 got my cluster for me. Cheaper than a decent tach that isn't 5" and blocking my view! The Haynes manual (which you should buy anyway) has the steps for yanking the dash trim and swapping the odo units in chapter 12.
PS I remember answering the same question before I went offshore for a month ago....PLEASE read up on BOTH posts you left!
