Radiator question
Old May 10, 2005 | 08:15 PM
rmalottwtes30's Avatar
rmalottwtes30
Radiator question
I have a radiator out of a 351m and want to use it on my 300, it all fits and all but the bottom is the problem the hose is coming out on the left side of the engine but on the radiator its on the opposite side. Do they make long lengths of radiator hose? if so that would work.
Old May 10, 2005 | 08:51 PM
javi2001's Avatar
javi2001
As far as I know, there are no hoses for that... you can adapt universal long hoses with spring inside and Yes! it work but
Why not you change the side tanks and re-use radiator core???
Old May 10, 2005 | 10:07 PM
924x2150's Avatar
924x2150
Sounds difficult, I have a hard time getting the lower hose on the standard 300 radiator, I can't imagine how you could get that hose across to the other side.
Old May 11, 2005 | 02:07 PM
rmalottwtes30
I dont know much about them but the one that came out of it is all rotten, the stuff in the middle is and it leaks there, now all i have is the one out of the 351 but the bottom outlet is on the other side. are you saying i can take the sides off the other one and put them on the big radiator?
Old May 11, 2005 | 03:43 PM
Silver Streak's Avatar
Silver Streak
You will be ahead in the long run to go buy the proper radiator for the job.
Old May 11, 2005 | 08:16 PM
924x2150's Avatar
924x2150
I'm not sure if the two radiator side tanks are interchangeable, they are a pain to remove and replace unless you know what you are doing, and they would also need new seals on each side. Why not let a pro take a look at it?
Maybe they could flush the original core, and replace the seals for half the cost of a new one. One caution: I had my 12 yr old radiator flushed and refurbished, and one year later the plastic inlet cracked off the sidetank. When the plastic ages I guess it becomes brittle. I spent 150 for an exact replacement for mine. I installed it myself, and it has been OK.
Old May 12, 2005 | 02:40 AM
NM5K's Avatar
NM5K
I know money can be an issue, but usually for a
radiator that is *really* shot, I recommend just
biting the bullet, and getting a new one. Most
have lifetime warranties...I bought a new one in
2000 for my 68, and I've already had to replace
it once , as the top weld started coming loose.
Sure was nice to get a brand spanking new one
for free... It wasn't cheap, but unless the Co.
goes out of biz, I'll never have to buy another
radiator as long as I own that truck. And
being new, naturally it cools great too...But I'm
all for a re-rod if the old one is not too far gone...
You can get quite a few years on a good rebuild...
My 74 has the original that has been rebuilt once
quite a few years ago...
It looks pretty old, but still works ok..
I imagine if it goes south, being so old, I'll probably
buy a new one and get the lifetime warranty...
I like "lifetime" parts... Both my trucks have so
many lifetime parts, I can't keep track of them all...
Have a big wad of invoices in the glove boxes I inspect
when a part goes bad...Most of the time... yup...
Lifetime...Free again... Biting the bullet can save
you money in the long run. MK
Old May 14, 2005 | 02:00 PM
Pelican's Avatar
Pelican
I bought a new triple-core radiator for my 300 recently. It wasn't that expensive, and for what it's worth, I'd just get a new one.
Jimmygunz3
Dec 6, 2011 03:13 PM
8lug
Jul 28, 2010 10:42 AM
walander
Apr 22, 2010 01:37 PM
lgamech
Bronco II
13
Feb 12, 2004 06:29 PM
