stupid radiator question
Old Feb 21, 2010 | 10:41 AM
walander's Avatar
walander
Ok, so this is a stupid question, but im trying to replace the radiator in my 67 f100, and even thow its easy to find a radiator, im having a problem. What is the second hose on the bottom of the radiator for? the smaller outlet on the bottom left hand side? all the replacments I find in the junk yards dont have that outlet on them, thanks again
Old Feb 21, 2010 | 11:31 AM
jowilker's Avatar
jowilker
The two 3/8" in/outlets on the bottom of the radiator are for tranny cooling lines for like C6 autos.
John
Old Feb 21, 2010 | 11:39 AM
walander's Avatar
walander
No, this is one bigger 1 3/4" outlet, on the opposite side as the main outlet. and its a stick, not auto.
Old Feb 21, 2010 | 04:48 PM
starmilt's Avatar
starmilt
I would say heater hose but that would be 3/4 not 1 and 3/4.
Old Feb 21, 2010 | 06:25 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
All heater hoses used on these trucks are 5/8" I.D., not 3/4" and none go to the radiator.
At the far left (drivers) side of the lower tank is a brass adapter with inside/outside threads the radiator's draincock screws into.
This adapter was factory installed in all the radiators, but I dunno if an autoparts store replacement radiator comes with it...or not.
Old Feb 21, 2010 | 07:36 PM
GLR's Avatar
GLR
Possibly for an oil cooler? I've seen them on Chevs Also a 70 F100 6cyl I had was equipped with an oil cooler.
Old Apr 22, 2010 | 12:04 PM
walander's Avatar
walander
Ok, so now that the weather is warm, I went out to look at the truck, turns out, my kid measured wrong, it is infact a 3/4 inch hose, after looking into it, it is indeed a heater hose that runs to the radiator. I cant find another rad that has that same heater hose plug on it, can I just clamp it off? what would be the result from doing that? just no heater? I can handle that, or could I do some real damage. let me know, thanks.
Old Apr 22, 2010 | 01:37 PM
Ford_Six's Avatar
Ford_Six
Where does the other end of the hose go? Normally one heater hose goes to the water pump, and the other to the intake, then of course both go through the firewall into the heater core.
It is possible a line was re-run, or the truck could have had a circulating tank-type block heater installed.
jerry_s
Oct 21, 2014 02:05 PM
Ben24
Sep 6, 2013 11:59 AM
dyoungen
Mar 1, 2013 07:48 PM
dyoungen
Feb 9, 2013 09:01 PM
sancochojoe
Jul 7, 2006 08:49 AM
